Ana içeriğe geç
Turtle Beach Ear Force XO Seven, 2013 yazında piyasaya sürülmüştür. Model Numarası: TB300-2219-01. Xbox One ve mobil platformlarla uyumludur. Kulaklığı sökmek nispeten kolaydır ve yeni başlayanlar herhangi bir sorun yaşamayacaktır.
How can I stop right side creaking
Is there a quick and easy solution to stopping the right side rotator of the headset from creaking? The persistent creak is near unbearable, yet the left side in silent. Is there anything that I can spray in the joint or something because I'm just about ready to go buy a new headset.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
2 Yorum
anyone come with a solution to this problem??
Thanks.
tarafından
i fixed mine buy getting a set of hyperx core. i will never own turtle beach again
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
my XO seven was making a lot of noice in all the movable joints , i used wd 40 to lubricate the joins.
do 1 joint at the time , spray the joint , have a rag or paper towel to whipe of the any spills , move the joint and keep whiping , move on to the next , after all joints are done make shure there is no spills .
this will remove most creaking and noices from the joints.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
You lovely being. I didn't even think of WD40, I used oil first. Which didn't work at all. I bought the Arctis Pro Gamedac a couple of days ago and of course I was pretty !#^&@@ when my 230€ headset started creaking all of a sudden.
WD40 fixed it. I had totally forgotten about having that stuff. Thanks a ton !
tarafından
Hey Mike, I’m having the same issue with my headset. The hinge that connects the ear muff makes a creaking sound and there’s another lil hinge that is connected so you can rotate the ear muff up and down and the other hinge you can move side to side so they can lay flat if they are resting around your neck. How long did the WD-40 trick last for?. Thanks for the help.
tarafından
Yorum Ekle
Yanıtını ekle
Troy Schuster sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 6,185
