Blown resistor capacitor on the motherboard
Hi. I have a 11" Macbook Air and one of it's motherboard resistors had blow up.
http://s1.postimg.org/g2cffygfz/image.jp...
How to fix it?
Thanks!
Bu iyi bir soru mu?
How to fix it?
Thanks!
Bu iyi bir soru mu?
Vilson, that is C7540 which is a 62UF 11V 20% Tantalum - Polymer capacitor in a Case-B2S-1 package. You will have to of course solder the replacement back on. Biggest issue here is why it got damage. usually caused by a short circuit, so you will have to determine the cause of it.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 1,340
7 Yorum
What exact model is your MBA? Give us the last 4 digits of your serial number so we can properly identify your hardware.
oldturkey03 tarafından
This is the serial number:
http://s15.postimg.org/int34ynor/image.j...
Where I can get that capacitor from?
Vilson tarafından
I'd check with places like Mouser.com or Digikey.com. Of course there are plenty of others. Just a matter of looking around
Nothing in there. No idea where to look for it.
Vilson tarafından
Check for some with a lightly higher value. You can use some that have higher values, just never lower. A Sanyo 11TJSF62MAIG would be a perfect match. Not easy to find in small quantities. You may have to scrounge on dead circuit boards etc.
2 tane daha yorum göster
