How to replace front wheel ear
how do I replace a honda pilot front wheel bearing
Bu iyi bir soru mu?
Bu iyi bir soru mu?
chris, see if this will help:
Knuckle/Hub Replacement Special Tools Required
• Ball joint remover, 28 mm 07MAC-SL00200
• Hub dis/assembly tool 07GAF-SE00100
• Attachment, 62 x 68 mm 07746-0010500
• Driver 07749-0010000
• Support base 07965-SD90100
• Attachment, 96 mm 07948-SB00101
• Attachment, 86 mm 07VAD-P8A010A
1. Raise the front of the vehicle, and make sure it is securely supported.
2. Remove the wheel nuts and front wheels.
3. Remove the brake hose mounting bolt .
4. Remove the caliper mounting bolts , and hang the caliper assembly to one side. To prevent damage to the caliper assembly or brake hose, use a short piece of wire to hang the caliper from the undercarriage.
5. Remove the wheel sensor from the knuckle . Do not disconnect the wheel sensor connector.
6. Raise the stake of the spindle nut , then remove and discard the nut.
7. Remove the brake disc retaining screws.
8. Screw two 8 x 1.25 mm bolts into the brake disc to push it away from the hub. Turn each bolt two turns at a time to prevent cocking the disc excessively.
9. Remove the brake disc from the hub.
10. Check the front hub for damage and cracks.
11. Remove the cotter pin from the tie-rod end ball joint, then loosen the nut.
12. Remove the tie-rod ball joint from the knuckle using the special tool.
13. Remove the lock pin from the lower arm ball joint castle nut, and remove the nut. NOTE: Do not force or hammer on the lower arm, or pry between the lower arm and the knuckle. You could damage the ball joint.
14. Remove the lower arm ball joint from the knuckle using the special tool.
15. Remove the damper pinch bolts and flange nuts from the damper.
16. Pull the knuckle outward, and remove the driveshaft outboard joint from the knuckle by tapping the driveshaft end with a plastic hammer, then remove the knuckle.
17. Separate the hub from the knuckle using the special tool and a hydraulic press. Be careful not to deform the splash guard. Hold onto the hub to keep it from falling when pressed clear.
18. Remove the snap ring and the splash guard from the knuckle.
19. Press the wheel bearing out of the knuckle using the special tools and a press.
20. Press the wheel bearing inner race from the hub using the special tool, a commercially available bearing separator, and a press.
21. Wash the knuckle and hub thoroughly in high flash point solvent before reassembly.
22. Press a new wheel bearing into the knuckle using the old bearing, a steel plate, the special tool, and a press. Be careful not to damage the sleeve of the pack seal.
23. Install the snap ring securely in the knuckle.
24. Install the splash guard, and tighten the screws.
25. Install the hub onto the knuckle using the special tools and a press. Be careful not to deform the splash guard.
26. Install the knuckle in the reverse order of removal, and note these items:
• Be careful not to damage the ball joint boots when installing the knuckle.
• Tighten all mounting hardware to the specified torque values.
• Torque the castle nut to the lower torque specification, then tighten it only far enough to align the slot with the pin hole. Do not align the castle nut by loosening it.
• Install a new lock pin on the castle nut after torquing.
• Use a new spindle nut on reassembly.
• Before installing the new spindle nut, apply a small amount of engine oil to the seating surface of the nut. After tightening, use a drift to stake the spindle nut shoulder against the driveshaft.
• Before installing the brake disc, clean the mating surfaces of the front hub and the inside of the brake disc.
• Before installing the wheel, clean the mating surfaces of the brake disc and the inside of the wheel.
• Check the front wheel alignment, and adjust it if necessary.
2004-Honda-Pilot-Wheel-Bearing-front.pdf for more info from alldata
Bu yanıt yardımcı oldu mu?
You need to put in the torque values.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 10,956
