Low designed capacity and no low battery warning
I'm having an issue, after receiving the replacement battery I installed it in my MacBook Pro 13-inch (Mid 2012). Performed a reset of the SCM and PRAM, then allowed it to charge.
I notice that around 41% the MacBook Pro would shutdown. So I performed another reset of the PRAM and SCM. Then went through the process of recalibrating the battery. I read on your forum where a member recommended using coconut battery to help diagnose the issue. I had a look at the battery status while charging this morning and noticed that the design capacity was at 57.2%. Could you advise me on how I may fix this issue?
Bu iyi bir soru mu?
