Ana içeriğe geç
Model A1046 or A1095 / 1280x854 screen resolution
118 Soru Tümünü görüntüle
Soru Kapandı
Why display is so dim
When i turn on the display is so dim i can barely see the apple and fonts at all. When i tap brighten + button display gets bright for a second, then fades out to black again. I thought video card or logic board needs replacing. Dent in lower right corner indicates it was dropped at some point
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Move the screen back and forth to see if it is the inverter cables. If yes, replace the inverter cables. Nothing? Replace the inverter, here's how:
PowerBook G4 Aluminum 15" 1-1.5 GHz Display Inverter Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
To me this sounds like a back light issue it could ether be a loose connection or the back light itself has gone bad
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 125
