Ana içeriğe geç
Sony Xperia Z3 Compact released in Sep. 2014.
82 Soru Tümünü görüntüle
No backlight after screen replacement z3 xperia compact
I changed the screen because it cracked. When I first tried the screen it was fine and it worked. Then after a while the backlight didn't work. The screen works and I can barely see things on the screen, but backlight is not working.
I read there is a fuse that helps fix this issue but I don't know if this will help. Here it is: http://www.mobilerdx.com/2015/03/sony-xp...
It's the first time the phone is opened and I never thouched the fuse because it's underneath a metallic plate, which I didn't even touch or moved. So why would I have to do something with the fuse if I never did anything to it and the screen was working when I tested it?? It just stopped working afterwards for some unknown reason.
The phone is on, because there is the blinking light. So, do you have some suggestions??? Should I actually try to add a jumper on the fuse??
Thanks.
EDIT: I remember that when I was about to close the phone I put the screen upside down, and it was when the screen backlight stopped working. Is this some reason why the fuse could have been damaged???
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
i have the same problem. After I replace the screen of my phone. The brightness become so dim. I tested na light sensor but it is working.
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello all! I have same problem but trick with jumper not done result. I find problem in this chip J5cx http://prntscr.com/99khme but I can't find it for buying. I replace this chip from another xperia z2 and now its work.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Do you have more details with this replacement?
Where ist this chip located? Do you have other Fotos?
How do you remove and resolder it on place?
tarafından
Yorum Ekle
Hi, I had the same problem and took the risk of making the jumper. I used a conducting glue instead of soldering the thing because it is so tiny, I do not own the tools for it.
It worked fine using this glue, my screen is as bright as it should be!
Puan 1
Yorum Ekle
O have the same problem. After I replace the screen of my phone. The brightness become so dim. I tested na light sensor but it is working.
Puan 0
1 Yorum:
Sony's TFT LCD IPS Fuse exploded on Logic Board. Just solder it out. Use a Good Solder + Microscope.
Compact Z3: https://youtu.be/B3GHVfFs2hU?t=263
Logic BoardCHF 23.04 | 32GB Original Motherboard Für Sony Xperia Z3 MINI D5803 D5833 100% Entsperrt Mainboard Android OS Logic board Mit Chips ersetzen
https://a.aliexpress.com/_BUGwJ5
TFT LCD IPSCHF 17.92 | Original 4.6 ''Für Sony Xperia Z3 compact z3 mini D5803 D5833 LCD Display Touchscreen Digitizer Montage mit rahmen ohne Frame
https://a.aliexpress.com/_B0hkDt
Normal Big Z3: https://youtu.be/ZUm7n0tCZVM?t=45
5803 = EU + USA
5833 = Australia + Asia
https://www.quora.com/What-is-the-differ...
tarafından
Yorum Ekle
Hey Mel.. Did you fix it? I have the same problem
Puan 0
2 Yorum:
I got someone to fix it for me. I didn't do it because you need the tools and I didn't have them. But where the picture shows is where you need to solder. The guy that did it soldered a very thin metal cable in that spot. So yes, it should work. It's how I got mine fixed. But you definitely need tools for soldering such a small part. It's not easy. I tried it and couldn't do it. So I had someone do it for me.
tarafından
Yorum Ekle
Hi there. I've replaced the screen of my z3 compact. I think have connected the lcd screen properly, in fact it turns on, but the touch screen is not working. Can you help me to get why and fix it?
Puan 0
Yorum Ekle
Did u solve it? Ihave same problem
Puan 0
Yorum Ekle
Hi,
please see this answer: Replaced Screen But Blank Display
I hope this helps!
Puan 0
Yorum Ekle
Hi all,
got a similar problem. The backlight of my Sony Xperia Z isn't working after I replaced the backcover only, I haven't touched anything but the backcover and two screws that fell out, as I opened the phone's back. Anyone think it's still the fuse or got any other idea?
Puan 0
Yorum Ekle
Yanıtını ekle
Mel Dominguez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 22,829
