Ana içeriğe geç
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
22 Soru Tümünü görüntüle
lens error-message-please turn camera off and on again
When turning camera ON, all appears normal for a few seconds, then the ERROR MESSAGE "PLEASE TURN CAMERA OFF AND THEN TURN ON AGAIN".
When turning OFF, the lens stays out.
When turning back ON, the lens retracts, then extends and stays out, and the process repeats. (The shutter does not work during the few seconds that operation appears NORMAL.)
I've replaced the battery with a fully-charged one. No difference in operation.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It sounds like the lens is jamming. You might have some physical damage, some debris in the gears or mechanism, or it's just worn out. You could try taking it apart and cleaning out the gunk. Good luck, but you will probably end up buying a new, better camera.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jhkmtk44 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 2,125
