How to replace rear axle bearkings
how to replace rear axle bearkings
Bu iyi bir soru mu?
It s a long process so Ill let someone else show you
https://www.youtube.com/watch?v=BKcK6WqS...
https://www.youtube.com/watch?v=zjZmG4qw...
https://www.youtube.com/watch?v=3lUykh8H...
https://www.youtube.com/watch?v=7Pds5Knn...
https://www.youtube.com/watch?v=BTNNjpkE...
https://www.youtube.com/watch?v=Kz_pWqXX...
https://www.youtube.com/watch?v=zAwq3Fcn...
Lot of video but very detailed
Bu yanıt yardımcı oldu mu?
its in parts 1-7
carmieandjason see if this will help you out:"
Removal (With Rear Drum Brakes)
1. On vehicles with air suspension, turn air suspension switch to OFF position. On all vehicles, raise and
support vehicle. Remove wheel assemblies. Remove differential housing cover, and drain lubricant. Remove brake drum.
2. Remove and discard differential pinion shaft lock bolt. Remove pinion shaft. See Fig. 2 . Push axle shaft inward and remove "C" locks. Remove axle shaft, being careful not to cut axle seal. Using a Axle Wheel Bearing Puller (T83T-1225-A) and Slide Hammer (T50T-100-A), remove bearing and oil seal as a unit.
Here is a great guide.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,061
