Ana içeriğe geç
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
My triggers and (a) button dont work
hey i was doing some diy mods to my xbox one controller (i changed the d-pad triggers bummers and joy sicks to white) and now my trigger either are unresponsive or are shooting and aiming non stop. also my (a) button only works in game when i go to the xbox menu or homescreen i have to click the button 3 times to get it to work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
bump? i still have this problem
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
hey Im having the EXACT same problem (even the xbox menu/in game 'A' button issue), bumping for some help.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
have you found anything out?
tarafından
Yorum Ekle
I have the same problem. What happened was I accidentally scratched the magnetic sensor for the triggers and now I have to order a whole new mother board and I don't know about you a button....
Puan 0
2 Yorum:
can i ask were you bought the new board from ? and it is only the one board or are you buying both
tarafından
Well I bought it on this web sight but you can probably find it cheaper if you do some research but I only needed the thumb stick mother board or the bottom to fix the trigger but if your a button isn't working too your best bet is to buy a new controller because to fix that you need the other mother board...
tarafından
Yorum Ekle
I have the same problem, i bought the controller new (the warranity expires 2 days after) the left and right triggers are not tight but they keep aiming and firing
Puan 0
Yorum Ekle
Yanıtını ekle
killerbunnies KB sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,186
