Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
How to "fix" broken keyboard backlight ribbon cable port?
I have a macbook pro mid 2010, 2.4 GHz A1278 model and I recently opened it to clean because of a liquid spill. Luckily the liquid did not go in deeply that after I cleaned the inside parts it's working perfectly except for the keyboard backlight stopped working. Pressing keys F5 and F6 shows the backlight level on the screen but nothing really happens. And i realised that the keyboard backlight ribbon cable port, on the logic board, is broken( only the tiny clipper part that locks the cable).
My question is is there any simpler way to fix this other than replacing the logic board for the backlight to work? Any suggestion would be appreciated.
Update (09/04/2015)
Hi Sterling,
here is the actual picture of the part that's missing, Its the small plastic part that holds the keyboard backlight cable in place. difficult to get a good resolution picture with a ordinary camera but i tried my best.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
Can you post a photo of the broken clip?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Is it possible to push a little bit and just wedge the cable in there? I didn't remember there being a clip there, but I may be wrong. Is it possible the backlight itself was damaged in the spill?
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
is there a part number for this clip? I have the same issue and it seems the clip is missing off the ribbon
tarafından
I also have this problem. Does anybody have an answer?
tarafından
Yorum Ekle
Yanıtını ekle
Henock Girmachew Mullissa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,864
