Ana içeriğe geç
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Soru Tümünü görüntüle
Soru Kapandı
Formating to Mac OS Extended
Should I format to Mac OS Extended (Journaled) or Mac OS Extended (Case-sensitive, Journaled)???
Update (09/05/2015)
It's Mac OS X 10.5.4???
Update (09/05/2015)
Thanks for helping me we all appreciate it!!!;~)
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This gets into file names case. As an example the file MY.TXT, My.TxT, my.TXT, my.txt would be seen as different files and all could live within the same folder if you had selected Case-Sensitive.
If you had set for the default the file MY.TXT, My.TxT, my.TXT, my.txt could not exist in the same folder as the system would treat them all as the same file. If you had tried moving one of these into the folder the OS would ask you if you want to replace the other file.
The short of this is this use the default Mac OS Extended (Journaled) ;-)
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
This was a continuation of this question and does not really stand alone as a independent question: Finding destination for installing operating disks..
Also some comments have been deleted that I made and do not show up in the history making the conversation hard to follow.
tarafından
Yorum Ekle
En Yararlı Yanıt
Puan 3
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 111
