Ana içeriğe geç
GoPro’s seventh generation camera released in late 2012. Capable of recording 1080p30 video, waterproof to 197', and built-in Wi-Fi.
Wont Turn On / Cable Gets Hot
Hello, I am a guide on the river and we were out playing and swimming and I found a GoPro at the bottom of the river. It worked for about 3 months then I took it snowboarding and it just shut off. I tried to charge it and it won't charge. I bought a new batter and it won't turn on or charge still. Also the charging cord gets really hot when I try to charge it. GoPro won't fix it because I didn't buy it and I found it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Andrew Davis, heat=shortcircuit. Right after you found it and tried to find the owner unsuccessfully you should have disassembled the GoPro and cleaned it with some 90% isopropyl alcohol. You most likely now have corrosion damage on the board and the components have shorted out. Disassemble it and see if you find some obvious damage. here are the guides for it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Andrew Davis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 572
