Ana içeriğe geç
MK4 veya Bora olarak da bilinen dördüncü nesil Volkswagen Jetta, Volkswagen'in aile sedanıdır.
not shifting into overdrive
two things i would like to know the location of my tcm trans control modular in my 1999 vw jetta 2.0 newer body style. and why do you think the trans is not shifting into overdrive what should i look for mick
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have a 2002 Jetta 2.0 that wouldn't shift into overdrive. We changed a speed shift sensor, it didn't fix it. Come to find out, there's a speed shift sensor on top of the transmission under the transmission mount. It has a cord with a plug in attached to it, where as the other speed shift sensors don't have a cord connected to them. This fixes it. You also have to reset the transmission computer afterwards. So to do that turn the key in the on position without starting the car. Then hold down the gas petal for 30 seconds. That's it, good it go!!
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Is it necessary to have a speed shift sensor for overdrive in the Jetta?
tarafından
Yorum Ekle
The TCM is below the wiper cowl along with the ECM. It might be low on ATF, which would prevent it from shifting into overdrive.
Puan 0
1 Yorum:
As far as I know it has a sealed transmission.
tarafından
Yorum Ekle
Because attacks 5 and 1/2 Grand at because I have to drive it up to 40 miles an hour to get it to shift out of second and then I can put it up to 80 miles an hour and it won't shift again and I'm tacking 5 1/2 Grand
Puan 0
Yorum Ekle
i change the body valve whit at new wire conector and transs dont shift gears please helpme
Puan 0
Yorum Ekle
Yanıtını ekle
RADIOFLYER sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 16,165
