Ana içeriğe geç
After Repair: Home button working, Touch ID not
I just finished swapping my screen after two cracked ones and a malfunctioning one. After these three fixes, everything was working perfectly fine (except for the screen on the last two changes; bought from the wrong person I guess). Now, after putting in the newest screen (and having to readjust the cables as one wasn't in all the way, making this newest screen malfunction…) Touch ID is no longer working. When trying to activate it, it sends me to a "Failed" screen immediately after trying. Does anyone know what this problem would be? I've tried readjusting both Home button connections and nothing seems to work. If I did damage it, can you give me a link to the part I need to repair it? Thanks for any help!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
You have to use the OLD home button. I f your new screen came with camera and home button already installed, that is usually the case.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
It is. That's the problem.
tarafından
could you be more precise? what IT IS means - you tried it or it comes with home button?
tarafından
Yorum Ekle
Try to reset the touch ID. Your old touch ID data has been disable after screen replacement.
Puan 0
2 Yorum:
How'd you go about doing this? Is it something in the OS or the hardware?
tarafından
Just reset everything. Nothing. Any other ideas?
tarafından
Yorum Ekle
Your Touch ID is linked to the device you can't replace with new button without loosing the Touch ID function.
Puan 0
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 377
