How do I fix the door?
My passenger side door is stuck, how am I suppose to get the panel off if it's stuck?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
i am a mechanic and this is one of the most tricky things to do depending on the problem. all you can do is move the seat as far out of the way as you can, get as many retainer screws as you can see out, and try to gain enough room to get your hand between the door panel and the door, and try to get on a lock rod or the door latch itself. make sure the door is unlocked even if the rod looks like it is. it takes LOTS of patience, but you can get it if you take your time. best of luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 2,524
1 Yorum
Can you clarify what part of the door is stuck? Was it hit and won't open? Will it not unlock? Did someone super glue the door shut?
David Hodson tarafından
