Ana içeriğe geç
1.9" renkli ekrana ve MicroSD yuvasına sahip, flash tabanlı bir Video/MP3 oynatıcısı olan Sansa Fuze için onarım ve servis bilgileri. Mart 2008'de piyasaya sürülmüştür.
Very Frequent White Screen Of Death
Everytime I turn it on to use it, a white screen of death pops up. I reboot it by holding down the slide switch and after 3-5 reboots it stops showing the white screen.
Bu iyi bir soru mu?
Puan 3
1 Yorum
Turn it off and then turn it on while holding DOWN BOTH BUTTON ON THE FACE AND THEPOWER BUTTON ON THE SIDE UNTILIT TURNS ON. It worked for me.
sonofkerry2
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
spotlightsrule this sounds like an issue with either your firmware or with your LCD. Check on hereabout the reset of your Fuze. If that does not work you do want to disassemble it carefully by using this guide SanDisk Sansa Fuze Sökme. From there check the LCD connector for any corrosion, bend pins etc. You can try and reseat the LCD cable. If that should not resolve it I would consider replacing the LCD.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Did you try opening it up and checking the soldering points to make sure that there all in tact? That will most likely be your problem. I have a few more ideas of what the problem is if that was not it.
Puan 0
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 36
Her zaman: 2,843
