Ana içeriğe geç
Touch screen unresponsive when touched but 100% visible
I replaced the screen on my gold 6 plus, I decided to put a black screen on Iit and everything went well until I turned the phone on and the screen was unresponsive to touch. Before complete installation I did test the screen and it worked . The screen has light lines running down the screen please help
Bu iyi bir soru mu?
Puan 0
2 Yorum
Does the home button work?
tarafından
I didn't attach the home button backing plate yet because I have a stripped screw and ordered a new plate, but the touch id was still funtioning
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would take the phone apart again and get it to were it worked before then re assemble slowly and with care checking when possible if it works to know when things go wrong.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Sounds like the digitizer flex cable or socket on the board may be damaged. I would inspect those areas under a microscope.
Puan 1
2 Yorum:
Could also be a short , did you put all the insulating tape back on?
tarafından
When I extend the flex cable while it's plugged in the screen becomes clearer, but still lines going through
tarafından
Yorum Ekle
Your digitizer flex isnt properly plugged in most likely.
Puan 0
1 Yorum:
tarafından
Yorum Ekle
Touch input all jacked up after multiple screen replacement attempts
^Try this.
Puan 0
Yorum Ekle
Yanıtını ekle
Josh B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 329
