Ana içeriğe geç
Şubat 2014'te piyasaya sürülen, özel bir Android 4.4 KitKat sürümüyle çalışan ve SM-T520NZKAXAR model numarasıyla tanımlanan 10,1 inç tablet.
Why isn't my front camera working?
I've tried taking pictures on my Samsung tablet but when I do the camera isn't actually taking any pictures. Neither is anything showing up in the camera app. The camera on the back still works, just the front one not working.
Bu iyi bir soru mu?
Puan 7
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your device camera might have to be replaced or you might have a software issue. If it's a software issue; you can do a soft reset by holding down the power button for 8 seconds until the device turns off. If that method doesn't work you can do a hard reset of your device but make sure to perform a backup so you wont lose all of your data. If that method doesn't work you can put your device into recovery mode by holding these buttons at the same time while your device is off; power button, volume up, and home button. Use the volume button to scroll and select the option wipe device/factory reset. Then select all user data and press the power button to confirm. If this method doesn't work you might have to replace the motherboard. You can find replacement guides for the device on this page.
Samsung Galaxy Tab Pro 10.1 Troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Have you recently replaced replaced the glass ? Often when you replace glass the bonding material can cover the lens, or disconnecting the camera altogether. Hope this helps
Puan 1
Yorum Ekle
Yanıtını ekle
Stephen Yeung sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 12,031
