Why isn't my tablet making any sound?
My tablet isn't on mute or silent, and my volume button works and is turned on. However, it isn't making any sound or noise at all no matter what I do.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If it's a software issue; you can do a soft reset by holding down the power button for 8 seconds until the device turns off. If that method doesn't work you can do a hard reset of your device but make sure to perform a backup so you wont lose all of your data. If that method doesn't work you can put your device into recovery mode by holding these buttons at the same time while your device is off; power button, volume up, and home button. Use the volume button to scroll and select the option wipe device/factory reset. Then select all user data and press the power button to confirm. If this method doesn't work you might have to replace the motherboard. You can find replacement guides for the device on this page.
Take a look at this page if you come across more problems on your device.
Bu yanıt yardımcı oldu mu?
Thanks for your answer my device it perfect again I was so upset when it lost volume when I was in lock down due Corona Virus inside house
Where is the power button.
-_-
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 49
Her zaman: 22,737
2 Yorum
Did it get dropped
Jimfixer tarafından
I did not drop it
Donna Peterson tarafından
