Ana içeriğe geç
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
Cannot install on windows 10
Original Post: Epson WF-2540 printer
Cannot install Epson printer WF-2540 setup will not fully install the drivers. I have this problem on both computers. Before when I had windows 8 I had no problems, I upgraded to windows 10 cannot get printer to work. What can I do?
Bu iyi bir soru mu?
Puan 3
3 Yorum
Try running in Windows 7 compatibility mode
tarafından
In compatibility mode where you see Windows 7 or 8 remove the check mark. Restart your computer then try again. Worked for me.
tarafından
hi...you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Boot up in Safe Mode and see if it will install. That failing,
Try the instructions here: http://www.epson.com/cgi-bin/Store/suppo...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
The web page is no longer available.
tarafından
Yorum Ekle
Mine works... I just used the add printer feature in windows and let it find the printer and load the drivers... No issues. Try it that way.
Puan 0
Yorum Ekle
hi...the link in the answer above is not working, meanwhile you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
Puan 0
Yorum Ekle
Epson have drivers for Windows 10 x64 and 32 bit (among other OS)
https://www.epson.no/support?productID=1...
I have installed it and it works on Windows 10 x64 1803.
The printer otherwise is a piece of junk. scanner ADF does not accept any paper thicker then Rizzla cigarettes paper.
But most infuriating, the printer refuses to print anything unless all 4 ink cartridges are read not empty. So if I have a new black ink installed, and only want to print in B&W or greytones the printer will refuse. This is to help me.
I will never buy Epson again.
Puan 0
Yorum Ekle
Yanıtını ekle
Murven Kelley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 13,257
