How do I disassemble my Jbl Charge 2?
My Jbl Charge 2 sounds distorted, sounds like if the speaker popped, and I only used it for like a month.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I need to know this as well. There is a french guy dismantling it on youtube, but I can't understand what he's saying!
Bu yanıt yardımcı oldu mu?
Your front facing speaker panel pops off with to space brackets at the top and a solid one at the bottom peel it from either corner and it will pop off in each speaker has four screws on it and then you're allowed access to the site screens which allow you to open up the sides and the bottom part where the rubber you can heat up with a blow dryer and include adhesive and peel it back to show four screws you can undo to release the panel for the charging port section
Had this happen to me as well but the retailer had me contact JBL for an exchange. Still waiting to see how that works out. But there is a manufacturers one year warranty if you have the purchase receipt.
I will make a video and post a few pictures tomorrow if you like. It seems that nobody took the time to do so after a year.
UPDATE: here is the tutorial: JBL Charge 2 Démontage
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 10,278
I have a charge2+ which I am pretty sure is not counterfeit (sent pictures to JBL service center) but it does not come apart the same way as my other charge2+. The battery compartment is totally different and it looks as though I should pop the end caps off. However, I don’t want to do that without getting confirmation. Has anyone seen a charge2+ with 3 silver screws by the speakers holding two halves together and no screws for removing the end cap cover assembly?
runningwithcrimpers tarafından
Hi, i have the same Charge 2+. How did you get off this end caps?
Raffi tarafından
Hello again, i got it. You can turn the End Caps and get it off.
Raffi tarafından
