Ana içeriğe geç
The Kodak EasyShare C913 is a 9.2 MP digital camera.
10 Soru Tümünü görüntüle
Camera not turning on.
I got this camera for my wife. She's been using it without any problem. But after she put it away for a while, the camera would not turn on even with new batteries installed. She probably did not use the camera for 3 months or longer with the batteries in it. Did the batteries ruin it?
Bu iyi bir soru mu?
Puan 5
1 Yorum
Thank you all for your suggestions, but the camera still does not turn on because I don't think it's the batteries. There was no corrosion at all. It might be a short circuit in which case I have no way of fixing it except to take it apart. Even if I did that, I would not know what to look for.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you tried a water and baking soda mix. Using a Q-tip to clear up the acid?
Bu yanıt yardımcı oldu mu?
Puan -1
Yorum Ekle
En Yararlı Yanıt
NINO Sylmar, just to clarify those batteries do not leak acid. You most likely were using standard alkali batteries, there is no acidic electrolyte. The substance that leaks from those batteries is potassium hydroxide which is alkaline and can cause severe corrosion. Clean it properly with a qtip and some vinegar. Then dry it of with a qtip and some sterile water, rinse with isopropyl alcohol.
Puan 3
1 Yorum:
cleaning the battery terminals worked just like a miracle ! I was ready to break the camera until I tried this.
tarafından
Yorum Ekle
This must be a common issue with Kodak. Pathetic
Puan 0
Yorum Ekle
Team - believe the common issue that many customers experience with this model Kodak camera is that new batteries don’t resolve the issue and there is no obvious corrosion present to clean up, so please advise what else the problem can be for the majority who don’t have a leaky old battery issue as the reason the camera (in good condition) won’t power up with new batteries. TY.
Puan 0
1 Yorum:
One of the lower battery terminal touch points has become detached. This is located through the plastic body and is not easy to reinstall.
tarafından
Yorum Ekle
Yanıtını ekle
NINO Sylmar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 31
Son 30 gün: 116
Her zaman: 4,045
