Why does my computer beep at me when I turn it on?
When the power button is pressed the computer beeps repeatedly and does not turn on.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
A computer that is beeping when turned on indicates that an unrecoverable error occurred during the Power On Self Test, and that the display could also not be enabled to show an error message. The beeping is an indicator of what problem was encountered. Identify what the problem is with the manufacturer's beep code guide in order to find out what to do to fix the problem.
Bu yanıt yardımcı oldu mu?
unplug all devises power cord etc. shut down. then press power key and mute key (f-6 key) same time and hold for about 20 seconds. then turn back on this should fix the issue
It worked for me
Because there is no memory
Hi
Maybe your keyboard had som wet or water so some button active all time
You need to replace keyboard.
plz my keyboard is not had som wet or water
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 14,609
