will it work with an intel slb6b processor?
have 2 gb of ram 159gb hdd wirh a intel dual core 1.80 processor and it hangs or stalls when using propresenter 5
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 650
the intel processor is 2.66 ghz / 6m /1333 /05A.core 2 quad core
Aeryn TwoFeathers tarafından
What are the model specifications on your current processor? You can check the socket of the compare those specs with those Intel® Core™2 Quad Processor Q9400S against what you have as a starting/reference point.
Abdur Rahman tarafından
Most likely, but still possibly not. The motherboard may not support the specific processor, but it is worth a try. The socket is the same. But you may need to install a new heatsink for the new CPU. It has a higher Thermal Design Power.
Check this link if you need help installing a CPU:
HP rp5700 Merkezi İşlem Birimi (CPU) Değişimi
Nikhil Shah tarafından
