Ana içeriğe geç
The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
How do I fix the spring for the SD card?
I have to fish the SD card out of the SD slot. I am afraid that one day it will get stuck.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Gently remove your SD card with a pair of tweezers to avoid further damage. When you insert the memory card, does it click into place? If not, there might be something small blocking the SD card contact. Carefully turn your camera upside down to remove any loose debris. Make sure you are using the correct memory card size for your camera.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Make sure to check inside of the SD card well there might be something soft blocking the contact point.
Puan 0
Yorum Ekle
Yanıtını ekle
Javier pulido sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 5,072
