suddenly turned off. not starting anymore
while watching a movie device gives the signal of low battery, after connecting the power socket device suddenly turned off. and its not responding any more
Bu iyi bir soru mu?
Bu iyi bir soru mu?
i've experienced something similar to this before, i fell asleep with my laptop ._. and when it fell down it bent the tip of the charger, the next day i thought nothing of it so i decided to use my laptop
however when my laptop had the low battery signal i immediately plugged in the broken charger.
little did i know that the charging port must have broken and possibly short circuited the motherboard. i had to get the entire motherboard replaced :I
i hope my experience can help you properly diagnose the issue you are having as well ^.^
Bu yanıt yardımcı oldu mu?
the fdmc is damaged if you run with charged battery the laptop will work but when get discharge you will not able to power on again it fdmc damage
What is fdmc damage
what's a fdmc ?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 954
I don't use my laptop some days.and my laptop was not starting but power here.how can I fix that problem?
Gaming Ishtiak tarafından
