Ana içeriğe geç
The Microsoft Lumia 535 is a Windows Mobile smartphone developed by Microsoft Mobile. It includes a 5-inch display and a 5-megapixel front-facing camera.
27 Soru Tümünü görüntüle
black screen in lumia 535
Lumia 535 I really don't know what's happen with it
it's just screen off even though it's in the Active mode
you can receive calls, charge the phone and even you can listen some sounds like plug in and out the charger regardless the black screen
simply
everything is running well unless the black screen
what I have to do? how can i fix it ??
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
5 Yorum
I have the same exact problem with my microsoft lumia 535 too. I don't know how to hardfix it. Any ideas to help?
tarafından
Same..screen gettin black n sometimes green while playing videos..i just nw bought my phn n im facing these many problems.....disappointed....
tarafından
Hello everyone, I have the same issue but in my case Everything is visible till the Lock screen and when the phone is unlocked, The Main Menu is not visible and the rest "Signals, Wi-fi, Date and time" are visible. What do you people think must have happened?
tarafından
Facing the same issue from Pakistan. Do you found any solution kindly share with me.
tarafından
how to window phone black screen resolve
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Barsakh, two things come immediately to mind. your ambient light sensor may have failed, keeping the LCD dark or your LCD has failed. Disassemble your phone and take a look at the board and all flex.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Same thing happened to mine and also the sound has gone there is no sound in the mobile and i have also tried to replace the whole screen unit still the light is not there.A repairing guy told me that there is some IC which is faulty but he was unable to find it in market so it cant be fixed
Puan 2
Yorum Ekle
Nothing to do , it is os problem because this blank screen due to your not properly charging and until low battery to switch off,install games lot off , remove your battery without switch off,
etc......
Solution :
Switch off your phone then on
Reset your phone
this may useful for you
Puan 0
Yorum Ekle
I have hard reset my lumia 535 but the problem continued.
Puan 0
Yorum Ekle
Hello every1. i have the same blackening of screen & gave it to the service centre, they put me on a hold for a month and half and said this was a IC problem & they ordered it and after geting the IC they wil fix it and let me inform. so after 1.5mnths they called me back and said the IC was replaced and test it before me, my phon was working ok. But while i came hom & after recharging the same problm persisted. again i went to servc centr and they coud not find the prob and again put me on hold for another one month without any resolution. so i intentionally borought my phon back. but miraculously now the phon starts working and al the aplications are now working properly.
Puan 0
1 Yorum:
Please I have just got the same problem, I need help what can I do?
tarafından
Yorum Ekle
This is OS bug u cant do anything. The only fix i found is to downgrade to 8.1
Puan 0
Yorum Ekle
Your LED has gone bad. Take it to a cell phone repair shop to replace.
Puan 0
Yorum Ekle
try rebooting, that worked for me, although I’m sure it needs a technical fix.
Puan 0
Yorum Ekle
Yanıtını ekle
Barsakh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 22
Her zaman: 13,486
