Ana içeriğe geç
Canon EOS 60D, hareketli bir LCD ekrana sahip 18 MP bir DSLR (dijital tek lensli refleks) fotoğraf makinesidir. Kamera Ağustos 2010'da piyasaya sürülmüştür ve ön yüzünde yazan EOS 60D ibaresinden tanımlanabilir.
HELP! Error Code 70
I keep receiving an error 70 code when I try taking photos. I turned the camera off and back on, but after several photos the error showed up again. Does anyone know how to fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
1 Yorum
I get the Err 70 code to and can't do any thing else at all and after about a minute the camera shuts off. any help would be nice thanks
tarafından Paylaş
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If the automatic sensor cleaning is enabled, it causes an error 70.
That is, the automation solution is put off.
But I do not know what is the reason behind it.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
thanks seems to have solved my problem "THANK YOU"
tarafından Paylaş
Yorum Ekle
This is a memory card read/write error. First try to format the memory card. If the error continues after formatting (or the camera won't let you format the card), try a different memory card. If the error continues with a new card then you probably have an issue with the camera itself. Contact Canon for service. I hope this helps.
Puan 1
Yorum Ekle
Hey everyone.
My error 70 let me shoot in auto, CA, C1, C2 and C3 on my Canon 7d mark I.
After realizing I need to somehow update my firmware and that you cant update firmware unless in settings P, Tv, Av, M or B Ifound that if I set the camera to video I could use P and update the firmware I had loaded onto a formatted memory card!
Hope this helps someone else!
Puan 1
Yorum Ekle
I had this problem toobut the solution is to deactivate the autocleaning. The it shoots nornaly
Puan 0
4 Yorum:
I have this problem too and have format the card but still writing error 70
tarafından Paylaş
Please help me
tarafından Paylaş
Have AUTOCLEANING set to OFF
tarafından Paylaş
Please check image Sensor
tarafından Paylaş
Yorum Ekle
Hi, i fixed this error on my EOS 600D with Tornado EOS program. Do factory reset and problem solved.
Puan 0
1 Yorum:
what do you mean Tornado EOS program?
tarafından Paylaş
Yorum Ekle
I faced the same issue on my 60D.
Tornado EOS programn is really awesome! I used the free version to upgrade the firmware and problem solved!
Puan 0
Yorum Ekle
Yanıtını ekle
Tyler Vaal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 90
Her zaman: 26,935
