Ana içeriğe geç
Flash lens burned out, how do I fix it?
The built in flash rises up but the light does not turn on.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the camera battery is dying or faulty, it can cause problems with your flash. Remove your camera battery and charge it fully. If the problem persists, you might need to replace your battery. If your flash is burned out, you will need to replace it. Check out this troubleshooting page for more information.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
No reply on HOW to fix it.
tarafından
Hi @eyecue ,
If you click on the troubleshooting link above and then scroll down to the flash burned out section on the page there is a link to a guide that shows how to dis-assemble the camera so that access the flash bulb is possible so that it can be replaced. There are also some useful comments at the bottom of the guide.
Here's a direct link
Canon EOS Rebel T3i Top Cover Replacement
tarafından
Yorum Ekle
Yanıtını ekle
Tori Clayton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 4,334
