Ana içeriğe geç
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
My Cube can not enter the OS.
The Cube has some parts drop down( sheetmetal, screw ring and screw) when I install the AirPort Card last week.
It just hold the power on in a few seconds to off and restart continuously, it can not enter the OS platform.
You can see the parts' picture at this website.
http://mac.hk/appletalk/download/file.ph...
Thank regards
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would open it up, and look for any more loose parts, that may be shorting something out, and causing the cube to restart. If this doesn't work, then there is a problem with the power brick, or motherboard/cpu.
Also, try removing the airport card you installed.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
tarafından
tarafından
Yorum Ekle
Try Flashing the Image...
Puan 0
Yorum Ekle
Yanıtını ekle
Chris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,114
