Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
Fluttering lcd, sometimes an issue
So, recently, I've been noticing this issue, and it's very recent for me. Sometimes when I install a display assembly, I get fluttering lines, on the lcd. This isn't the same as when you use cheap parts, and you get those white lines. It's almost a strobing/blinking light. All the colors of the lcd picture are there. But they're doing the strobe effect. It's so weird, and I'm getting really good parts. So, I'm wondering if it's something I'm doing? Could it be my magnetic mat? Which Mav ruled out, in a different thread. Anything? Anybody? Oh, I've been getting this with iPhone 5S and iPhone 6
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have seen this same issue when the LCD Assembly is replaced while the device is still powered on. Make sure you are disconnecting power before you conduct a screen replacement. Also, if your cables aren't connected correctly and you power on the screen it can cause this issue. Hope this helps! Keep us posted!
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I could see the connections not being properly seated, as the result. Thanks!
tarafından
Flickering like that is usually a hardware issue, not software. It’s often caused by a loose connector, damaged flex cable, or the screen starting to fail.
You can try reseating the connector, but most of the time it ends up needing a screen replacement.
If you’re checking parts, you can look here: https://www.kiqparts.com/apple/iphone.ht...
tarafından
Yorum Ekle
Yanıtını ekle
iMedic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 339
