Ana içeriğe geç
1994 toyota pickup dies when put into gear
Have a 94 toyota pickup and when you put it into gear and take off it dies like you turn the key off not sure if it's a ground wire problem or what any ideas are helpful
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Do you have the same issue when it is not in gear? It only happens when you drive?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
It's not likely a ground problem. Probably a sensor. The only time I have had trouble with my truck not running it has been a sensor. Check all connections, unplug and plug back in. You'll probably fix your problem.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
You should also check to see it it's getting fuel when you have this problem. Could be a weak fuel pump.
Puan 0
Yorum Ekle
Yanıtını ekle
Jeremy Hedges sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 323
