Ana içeriğe geç
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Soru Tümünü görüntüle
Why doent My Mac pro Display?
bought a mac pro quad core CPU,but it has a problem with the display.though it boots,the display doesn't come on.what could be the problem and how can i fix this.have tried changing the VGA graphics card but there seem to be no positive impact this is so frustrating can anyone advice
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If your card doesn't have an Apple or Mac Edition ROM, the system won't show an image until OS X boots - this is normal. This is not normal on cards with an Apple or Mac Edition ROM. It's possible to flash a ROM to some of these cards, but this will void the warranty if you RMA it with the custom ROM flashed.
If you have verified you have a Mac Edition ROM or Apple ROM card, try using a different monitor. If this works, then you need to replace your display. If it still happens, check if the card requires PCIe power and if it's plugged in. If it does and you don't have the cable, you will need to order this. They generally aren't expensive and are easy to find.
If your card is hooked up and you have verified your card has the correct ROM and has PCIe power, you will need to replace the card.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kevin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 905
