Music wont play on the device
When I turn the cube on, the lights will flash but the music won't play. Is there a way to fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Simple solution is to turn it off and then turn it on again. If that didn't fix it then check the battery, if it's dry then put a new one and hopefully your problem will be solved. If the problem still occurs, then you might have a broken device and you should contact your warranty provider.
Check out the speakers troubleshooting page for the Munchkin Mozart Magic Cube:
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 468
