Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
What would I need to open a store?
Hello everyone,
I've recently been interested in fixing electronics (specifically smartphones) and Im doing some market research to open my own repair shop in Kuwait. I was wondering if any shop owners here could help me with regards to inventory. there are some questions that I'm finding trouble answering
1. what are the most common problem customers have
2. where can i find good whole sale suppliers
3. what sort of inventory would i need.
4. what tools would i need.
if someone could assist me in know where to start i would really appreciate it. if I'm asking this question in the wrong place or if you somewhere else where i could find more support that would also be great.
thank you,
Jubelot
Bu iyi bir soru mu?
Puan 0
1 Yorum
Per iniziare non farti mancare
1)attrezzi da lavoro
2) bella scorta di lcd cosi da essere pronto e preparato alle richieste dei clienti sostituzione rapida lcd e massima soddisfazione dei tuoi clienti.
3) macchina separatrice e protezione ESD
BUONA FORTUNA!!
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Jubelot What kind of repair experience do you have . Obviously not a lot or you would know what sort of things you need . So read this forum and look at the type of question you see the most . these are your most common problems . As for tools a heat station and solder station , a sonic bath , microscope for micro-soldering a multi meter. test light various spugers and pry tools micro screw drivers with various tip (pentalobe if you want to service iphones), screen puller . Just to name a few.Follow the forms and follow some of the veteran help to get some free advice from a good source . Follow @mayer , @oldturkey03 and @danj if you want to learn Hope it helps
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Hola como estas!! disculpa que te lo escriba en español pero es que tendría que escribir demasiado en ingles y no soy muy bueno!!!
Vas a dar un gran paso y para eso debes estar bien preparado, tener un excelente equipo y mucho conocimiento. deberías de empezar comprándote el equipo Pro de reparación en general.
1-El o Los problemas con los que los clientes mas buscan un centro técnico es para cambio de pantalla, pin de carga dañado, táctil dañado y cel en negro (que no hace nada).
2-Todo depende, tienes que recordar que si quieres buenos precios deberías comprar piezas al por mayor, normalmente los chinos tienen todo eso.
3-Necesitarías de todo, pantallas, pines de carga, táctiles, baterías, cargadores, cables usb, accesorios.
4-Como te mencione mas arriba, debes de tener herramientas Pro, destornilladores, pinzas, soldador, desarmadores, pulsera anti estática, etc.
Suerte y que te valla bien, recuerda todos los negocios al principio son difíciles.
Google Translate (Spanish)
Hello how are you doing!! apology you write it in Spanish but I would have to write in English too and I'm not very good !!!
You are about to take a big step and it must be well prepared, have an excellent team and a lot of knowledge. You should start by buying the Pro computer repair in general.
1- The o Problems with customers seeking a more technical center is to change screen, load pin damaged, damaged touch and cel in black (which does nothing).
2-all depends, you have to remember that if you want good prices should buy wholesale parts, usually the Chinese have all that.
3-You would need all, screens, load pins, tactile, batteries, chargers, USB cables, accessories.
4-As you mentioned above, must have Pro tools, screwdrivers, pliers, soldering iron, screwdrivers, anti static wrist strap, etc.
Good luck and you fence well, remember all businesses at first are difficult.
Puan 4
7 Yorum:
Google Translate says this is Haitian Creole and it just doesn't translate it. Please post your answers in a language that will translate so they will be of benefit to others..
tarafından
Translate to english seems to work fine but anyway. What does he mean by load pins? What are they?
Separating machine was mentioned on one of these answers. I think they shouldn't be used for starters and should be used after the person has repaired many phones.
tarafından
Ben sounds like dock connectors, lightning port etc. to me.
tarafından
Yes, charging ports for Android phones break a lot. S3 is a staple repair.
tarafından
Ben. I have no idea because it's not translated!
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Timothy 2:15King James Version (KJV)
15 Study to show thyself approved unto God, a workman that needeth not to be ashamed, rightly dividing the word of truth.
Puan 3
2 Yorum:
Wow didn't see that coming Amen
tarafından
@Jimfixer that is the other side of Pastor @mayer :-)
tarafından
Yorum Ekle
Jubelot on this forum "Answers" you find plenty of volunteers that will help you with any repair. Some of the great volunteers have their own business but we still focus on repairs. Here we focus on providing free help and are not concerned about how many people we can entice to use our fee-for-service. A while back ifixit came up with a forum strictly for the "pro's" I'd suggest you pop in there and see what their advice is.
Puan 3
Yorum Ekle
I think you should start by fixing a few hundred phones...
Puan 2
Yorum Ekle
the most important thing is that you know how to fix phones...
Puan 0
Yorum Ekle
Yanıtını ekle
Jubelot sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 344
