Ana içeriğe geç
7.1 megapixel camera by Canon, model SD750.
Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
Bu iyi bir soru mu?
Puan 0
6 Yorum
No memory card in my camera
tarafından
Use the camera to reformat the card.
tarafından
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
tarafından
When it says no card what will you firmat bro
tarafından
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Did you get my last response?
tarafından
I guess not. All I got was that one
tarafından
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
tarafından
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
tarafından
Yorum Ekle
Yanıtını ekle
mesarey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 5,218
