Ana içeriğe geç
Anahtarsız mandrene sahip, artık üretilmeyen 3/8 inç değişken devirli tersine dönebilen (VSR) matkap olan DeWalt DW106 için onarım ve sorun giderme kılavuzları.
Dropped Drill no response from trigger.
After 8 years of light use I dropped my Dewalt DW106 3/8 in VSR drill. 8 feet to a wooden deck. Since then it is dead. Opening it I see no loose connections. The motor turns freely by hand. The power cord is not frayed at any point. There is no smell or visible evidence of an electrical short inside the plastic shell. Have you any idea what part would be most likely to fail as the result of such a short drop?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Tried bypassing the switch to see if it will run without it?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hy
Maybe, like odlturkey03 wrote, the Power Switch itself ist damaged.
Try tu bypass the switch and see if it works.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
control all the wire connectors start from powercable > (supression coils) carbon brushes and their springs) the switch + (L+R ) and the electric field .
Puan 0
Yorum Ekle
Yanıtını ekle
supthehoop sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,040
