Ana içeriğe geç
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Ipad 2 is not charging, no turns on, black screen
Hi,
my Ipad2 GSM does not charge and does not turn on. (Working properly before discharging)
The charger and the cable were tested and working properly.
The connectors are clean and without damages.
By connecting it to a PC is not recognized
Ideas on what might have?
Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
6 Cevap
Filtre ölçütü:
Have you ever charging for too long? It is likely a hardware problem like mainboard is broken.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
No, I have always paid attention to the charging time and I never left the device on charge more than necessary.
Before it was fully discharge by connecting the charging cable appeared to me "device not in charge" but the cable and charger are ok.
It is not possible that it is damaged (for some reason) the flat cable between the charging connector and the battery or connector or something similar? unexpected death of the battery?
Puan 0
Yorum Ekle
Have you tried resetting it by holding the home and power button at the same time for 10 seconds ?
Puan 0
Yorum Ekle
Yes, I tried but no response and no Apple logo (although I think it's due to the fact that the battery is low). Other ideas?
Puan 0
Yorum Ekle
Some other tests or possible causes of the problem?
Puan 0
2 Yorum:
Have you tried a reset or DFU mode ? Were there any symptoms of a problem before this happened? Crashing? Quick discharge of the battery?
tarafından
I tried it but the combination power + home gives no result, by connecting the device to the PC is not detected and never gave any sign of abnormalities or sudden blocks.
It reported that the battery was used as normal and once the discharge everything and as if you are unable to charge more
tarafından
Yorum Ekle
Is there any answer?
Puan 0
Yorum Ekle
Yanıtını ekle
ModMatrix sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 763
