Why is my charger for ipad 2 gets hot?
when charging ipad 2 charging adapter gets hot.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Chargers getting hot is normal because about 220 to 240 AC volts are converted in the charger to 5 DC volts. Chargers contain components like transformers, resistors and capacitors (among others) which gives off heat under normal load.
Charger getting hot should not be a problem unless it happens even when the device (iPad in this case) is not connected.
Bu yanıt yardımcı oldu mu?
Connected to what? Mine is getting hot too. Is it a problem?
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 21
Her zaman: 11,464
