Ana içeriğe geç
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Soru Tümünü görüntüle
Soru Kapandı
Water damage, Strange GPU issue
Hello,
I had a Macbook Pro without a backlight issue and I asked for help here
Water spillage no backlight, fused fuse?
Now I managed to solder another LCD connector and the backlight is back. The problem is now I'm having a strange GPU issue.
Whenever there is a change between the discreet GPU and the integrated GPU my Macbook freezes and won't work unless I reboot it. For example, I turn it on and everything works until I open for example, iPhoto or Spotify or Chrome. The other way around also happens, if I turn the macbook on with an external monitor plugged they'll work fine until I unplug the external monitor. In that moment the macbook will freeze.
Has anyone experienced this issue? It's clearly something to do with the switching mechanism!.
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Does someone have the schematic of this board? It's clearly a hardware issue that the switching is failing.
tarafından
I downloaded the schematics but I'm overwhelmed by this. I have actually no idea where to start testing. I know the switch between iGPU and GPU is failing but no clue as to where this is in hardware
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
That sounds very strange indeed!
Would you be willing to attempt a windows bootcamp or booting a system on a usb to try and see if switching works in a different OS?
It sounds like a driver problem rather than a hardware problem because of no other problems than the lcd.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It's not a driver issue. I took it to Apple and they were unable to run the VST test as the screen suddenly goes black. Another example is, whenever I format the OS, I NEED another screen plugged into the HDMI as the internal screen doesn't show anything until the installation is complete. Very weird indeed.
The problem is that the mac is useless in this state, I'm unable to do anything that requires a little bit more of power
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 177
