Reset button does not work anymore
Hello everyone,
I have a 4th generation Time Capsule (A1409) that I can't use and reset anymore.
It is not recognized by Airport Utility anymore so, I guess I have to reset it. But the reset button seems to not work.
Nothing happens when I press and hold the reset button, even when I reconnect the station in the same time. (I did this many times in the past, and I was able to soft reset, hard reset and factory default reset when needed).
When reconnecting the power cord, the light will always turn green for a second, then flash amber slowly. There is no difference between holding the reset button or not during the power connecting process.
Each time I connect the unit, I can hear the hard drive and the light turns green then flash amber slowly, so I guess the power supply should be good... maybe I'm wrong?
Any idea about my issue or any other way to perform a factory default reset without using the reset button?
Thank you for your help,
Have a great day,
Francois.
Bu iyi bir soru mu?
