Ana içeriğe geç
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
Bu iyi bir soru mu?
Puan 4
1 Yorum
that fixed the problem. thanx.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Also, try visiting the troubleshooting page for more help.
Bu yanıt yardımcı oldu mu?
Puan 6
Yorum Ekle
En Yararlı Yanıt
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
Puan 18
12 Yorum:
Worked for me, i feel so stupid now
tarafından
Mine was not working either, Supid #2! Thanks!!!
tarafından
Wow! Thanks! *face palm*
tarafından
Add me to the dummy list! Thanks for the help
tarafından
Not working. Howwwee
tarafından
7 tane daha yorum göster
Yorum Ekle
Try resetting the watch.
Puan 3
3 Yorum:
I reset it and it only vibrates on phone calls.
tarafından
I reset mine nothing, no vibrating at all. I'll try again.
tarafından
Though it works, feels over kill. Try the quiet mode
tarafından
Yorum Ekle
No solution worked. No vibration at all even after hard reset
Puan 1
Yorum Ekle
My pebble steel started to vibrate again, after android wear app was removed
Puan 0
2 Yorum:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
tarafından
Thanks. I m on the top of the dummy list!!
tarafından
Yorum Ekle
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
Puan 0
Yorum Ekle
Yanıtını ekle
Orlandria Heggs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 15,833
