Ana içeriğe geç
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
Is it possible to replace the flash light?
Because the flash light is not working I want to replace it but I don't know if it is possible. I can't find anything about replacing the flash light and I don't wanna open the camera without knowing it. I can't find a replacement item either.
If anybody knows anything about this, please let me know, thanks a lot.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yes, it is possible.
You have to exchange the "Canon PowerShot S110 FLASH ASS'Y Replacement Repair Part".
This is hard to find but i got it on http://www.ebay.com/itm/Canon-PowerShot-...
Use the dis-assembly instruction for the display and remove further the copper foil under the display to find 2 further screws on the camera backside, remove these and also one screw on the assy frontside. Carefully disconnect the foil plug of the build-in assy and you can easily do a drop-in replacement of the assy.
My camera is again working.
Never manually push-in the flash of the camera. This will destroy the camera flash assy.
Good luck ;) !!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
i also have this problem with the s100..flash will not fire..the flash raises up..the program is set on flash..however, will not fire? have no idea why? if someone can give me advice to fix the flash..please give to correct my problem...thank you..
Puan 0
Yorum Ekle
Yanıtını ekle
justtrying sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 1,808
