Ana içeriğe geç
Canon PowerShot, 4x optik zoom özelliğine sahip 5.0 megapiksel bir fotoğraf makinesidir.
Camera will not work
When I turn the power on I get a reading on the screen that says "memory card error" and will not take a picture. Have tried a new SD card. Nothing helps.;
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
**Answering for completion**
This often happens due to the use of an SDHC/XC card - these are not supported due to the SD card controller in these cameras just being too old. The camera isn’t broken, and this error is very much expected.
You need a non-HC card, which are difficult to find now since HC/XC cards work in just about everything today. That said, the non XC capable devices are still easy to get cards for since HC is still very much a current spec. You can usually find these cards on sites like eBay used (be warned a lot of these cards have a ton of write cycles and will not last very long before showing signs of failure!), NOS or a new Chinese made card (more failure prone then a good name brand, but your best bet for cameras like this). Anything larger then 2GB is usually HC today due to volume cost making 4GB SD non-HC cards obsolete. Newegg has one, but there are no more “name brand” 4GB cards of the non-HC spec.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Rerick2 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,610
