Ana içeriğe geç
Released in 2012, this laptop features a Core i7 processor, dedicated Nvidia 620M GPU, and a 1080p display.
27 Soru Tümünü görüntüle
Thread size of screws on bottom of computer?
What is the thread size of the screws on the bottom of the computer (there are 12 of them)? I only have half of them left and would like to purchase screws to replace them (I called Asus and they were not able o give me the information)?
Bu iyi bir soru mu?
Puan 2
1 Yorum
There are eleven screws. Nine have a Torx 5 head and two have a philips head. I too am missing a couple screws. I also spoke directly with ASUS and they could not even tell me. %#*@, they make the things and cannot tell me what screws they use! Very poor. Perhaps some fab makes the systems for them. That is very common in the industry: Dell and HP use a fab, likely the same one.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
nadia, those are M2 (metric 2 mm screws) X 2.5mm length T5 screws.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
salut vous avez ce site https://www.asusparts.eu il suffit de donner la marque le modèle ou ici aussi https://www.zandparts.com/en/
tarafından
Yorum Ekle
Do they look like this? (Source)
It lists it as "M2*2.5L+0.5(3,0.3)(K)T5" on the parts site. I noticed it said T5, and the twelve screws are T-5 torx screws.
To be quite honest, I can't really determine what the thread size is based on that string of mumbo-jumbo, but it does look like measurements. The teardown does mention that these screws are not proprietary, so they should be readily available somewhere.
For what it's worth, I hope this at least helps point you in the right direction!
Puan 2
1 Yorum:
Hi M2*2.5L+0.5(3,0.3)(K)T5
m2 is the thread
2.5L is 2.5mm thread length
0.5 is o.5mm for head thickness
3 is 3mm head diameter
t5 is the drive type
hope this helps
you can find similar screws on laptopscrewdirect.com
they sell m2x3mm-t5 which will fit just fine
tarafından
Yorum Ekle
I actually got some free samples of these from https://www.vital-parts.co.uk/m2-x-3mm-t...
Different torx size in that its T6 but didn't really make any difference to me and I got them free (had to pretend I needed a few more...)
Puan 0
Yorum Ekle
Yanıtını ekle
nadia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 55
Her zaman: 30,266
