Ana içeriğe geç
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
722 Soru Tümünü görüntüle
My ipad is disabled how can I enable it without a computer
How do i enable my disabled apple ipad2 without computer or itunes
Bu iyi bir soru mu?
Puan 131
34 Comments
What does the screen say?
tarafından
Disabled try in20 min
tarafından
I have the exact same problem
tarafından
Ipad disabled connect to Itunes
tarafından
iPad disabled connected to iTunes
tarafından
29 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
There is no way to enable a disabled iPad without a computer. If you can use a friend or family members internet enabled device and can access www.icloud.com/find it is possible to remotely erase your device by following the instructions below.
The following instructions are from Apple's Support Website
If you set up Find My iPhone on your iOS device or Mac, you can use iCloud to erase and restore it.
1. From another device, go to icloud.com/find.
2. If prompted, sign in with your Apple ID.
3. Click All Devices at the top of your browser window.
4. Select the device you want to erase.
5. Click Erase [device] to erase your device and its passcode.
6. Now you can either restore from a backup or set up as new.
If your device isn't connected to a Wi-Fi or cellular network, you can't erase it with Find My iPhone.
Bu yanıt yardımcı oldu mu?
Puan 44
13 Comments:
I locked myself out of ipad2 did not sync nor did get to set up id quite yet
tarafından
what if i did not sigh up to i cloud on this ipad
tarafından
If you no have computer, and the iPad was locked, you can use Find My iPhone in another iPhone, but it's better to backup your iPhone first of all, and you from Find My iPhone, you can erase your iPad, so that you can unlock iPad without restore . Then restore from backup.
tarafından
will this erase the iPads data?
tarafından
Yes it will.
tarafından
8 tane daha yorum göster
Yorum Ekle
there is no way to do that as stated by @dylanfaraone above.... you may follow his instruction.
or find PC with itunes
Puan 6
Yorum Ekle
If you have an old backup then you can restore your backup then you got an option to insert a passcode for the final time.
Puan 0
1 Yorum:
@thegsmsolution can't restore from backup "without a computer" . This Question is 7 years old and the OP is long gone.
tarafından
Yorum Ekle
Yanıtını ekle
wednesday sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 132
Son 30 gün: 735
Her zaman: 304,876
