Ana içeriğe geç
Desktops developed by eMachines. eMachines has since been discontinued by the Acer Group.
My PC wont work!
When I turn it on there is a clicking sound and on the screen it has ...
Detecting array...
It does nothing else
Bu iyi bir soru mu?
Puan 0
1 Yorum
how old is you computer
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Do you have a raid system in you computer . This would mean two hard drives . if your computer is running in raid on IDE it would give this error if one of the hard drives was not working. you can start buy removing or disconnecting one hard drive at a time and seeing it will boot on one or the other alone. The clicking your hearing is probably the hard drive. Have you tried starting it more than once? Sometimes an old hard drive will get stuck and require a few tries to actually start, hope this helps
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Don't forget to reset your raid config in the bios
tarafından
Sorry missed that step thanks for the catch
tarafından
Yorum Ekle
As usual with broad questions there are many possible causes for this issue. Here is a short list of what I would check. If you are unsure about any of the terms or descriptions below DO NOT DO THIS YOURSELF, find a trained professional.
1. BIOS Settings
- If possible reboot the computer and press the correct key on your keyboard to access the BIOS, usually F2, F12 or even DEL. Once you are in the BIOS menu navigate to the RAID settings and ensure they are all turned off.
2. On-board battery
- Nearly every motherboard (after the companies stopped using the Dallas RT Chip) has an on-board battery. This battery ensures the BIOS does not lose any settings, but their voltage will eventually drop low enough that they no longer work.
3. Hard Drive
- It is possible that the hard drive has failed and the computer is unable to read it properly. This can result in the clicking sound described, which in my experience usually the result of the tiny read/write armature inside moving in ways it is not supposed to. Admittedly without actually being able to hear the sound being made this is all a guess.
There are other possibilities but these are the most likely causes, and can be found with any computer system.
Puan 1
Yorum Ekle
Yanıtını ekle
Sherry Arrington sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 1,234
