huawei ascend 510 dead wifi
sir my wifi is open but searching only not accept any wifi so plz help me
Bu iyi bir soru mu?
Bu iyi bir soru mu?
irfan sanam,
Hope below steps will help you to fix the fault
Step 01
Open System Settings --> Wireless & Networks -- >> WiFi connection, touch on the Wi-Fi network that you’re unable to connect and select option “Forget.” after that try to reconnect
Step 02
Open System Settings --> Wireless & Networks --> WiFi Connection, press Menu button and select Advanced----> select WiFi Frequency
Check with Auto mode and try to connect with 2.4Ghz band.
Step 03
Backup all data and Reset the phone. after resetting phone try to connect with WiFi
Bu yanıt yardımcı oldu mu?
after my phone get wet it didn't able to connect in wifi.. What should i do?
Check the WiFi chip, clean the chip using IPA and re-hot the chip. see whether chip bins to work. if not, check the 3.3 power rail present- if yes replace the WiFi module
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 5,307
2 Yorum
ewhing was stoped howe i can repaer som one tol only to change plak aqllryt
Agim Haliti tarafından
This should another question, not an answer to one, also what is an ewhing, plak and aqllryt
Cameron tarafından
