Ana içeriğe geç
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Soru Tümünü görüntüle
Why does my MacBook sometimes not boot up?
Hi,
I am having some very odd issues with my MacBook.
I recently had a problem with the MacBook not booting up. So, I tried resetting the SMC and PRAM, which had no effect. So, I opened up the laptop, disconnected the battery, reconnected the battery and then it booted with no trouble. Everything was then working fine until I then shut down the computer. The next time I came to turn it on, I encountered the same issue. On a disconnect and reconnect of the battery, all was well again.
Any ideas on what I can do to fix this annoying problem would be massively appreciated.
Thanks In Advance!
Scott
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
What does it show when you press the battery test button?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Mayer, as always, is on point.
With the system booted, try following these directions: https://support.apple.com/en-us/HT201585
That should provide some detail to let you know if this is a battery issue, which is most likely.
Also... much like the battery and alternator relationship in a car.... remove the batter and boot with just the power cable. If it works... and booting with the battery alone doesn't, it's likely the battery. Though, you're having intermittent issues, so I'm not sure if you would be able to get definite results.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Thanks for the complement. Looks like you can handle this one ;-)
tarafından
Of course. I don't know if you remember this, but you helped me greatly some time ago in getting my a1260 back up and running. I owe you for that.
tarafından
Brandon - Helping others is thanks enough. Your check got lost in the mail ;-) Glad you're here.
tarafından
Yorum Ekle
Yanıtını ekle
Tekkies Europe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 220
