Ana içeriğe geç
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Soru Tümünü görüntüle
Why cant I log into google play or any google service?
My tab wont let me log into my google account on gmail or google play it always says no connection i was told it might be a memory problem but how coukd i tell if its a memory problem ive had my tab for a little while and i cant download apps or sign in and its getting annoying. How can i tell if its the memory and if it is how much for a replacement
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Is you internet connection through 4g or wifi?If its4g make sure your getting a signal if not make sure your wifi connections working ok? You may also want to check and see if you may have your setting on airplane mode. Go into settings and check your network settings
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Try to Hard reset tablet using Power + Volume up + Menu. it will reset the setiing to default.
If this problem is due to malfunction of Software, Hard Reset will set it to default.
Hard Reset Tablet using Key combination
Puan 1
Yorum Ekle
Yanıtını ekle
lisadouglas100 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 913
